I've been having some problems capturing video using Pinnacle DC10+ in Win98SE. According to its brochure, this card is capable of capturing video at 768*576, 25fps (PAL).
Until now I haven't been able to capture video at 768*576, 25fps (PAL). Pinnacle Studio 8 only captures the first frame of the video whenever I'm setting the frame at 768*576. Actually, the maximum capture resolution I've been able to set in Pinnacle Studio 8 is 720*540, 25fps (PAL). On of the technical support I contacted even stated that 720*540 IS the REAL maximum, NOT 768*576 as stated on its brochure. The guy also stated that there is no driver whatsoever to enable DC10+ to capture at 768.576.
However when using AVI_IO, I'm able to set the capture resolution to maximum 768*560, or 592*576. So despite of this, I believe that there should be a way somehow to enable DC10+ capturing at 768*576. Has any DC10+ have encountered this kind of problem? How to solve it?
Results 1 to 1 of 1
Maximum 16:9 resolution for DVD?
By Paul Hetherington in forum Newbie / General discussionsReplies: 8Last Post: 19th Mar 2012, 04:29 -
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 03:03 -
Software for S-video output on Pinnacle DC10 plus card(XP)
By Eightbitgnosis in forum Software PlayingReplies: 2Last Post: 30th Jan 2010, 09:33 -
Pinnacle AV/DV2 or DC10+B miserable performance
By cybertheque in forum Capturing and VCRReplies: 1Last Post: 17th Sep 2008, 21:44 -
Pinnacle DC10 Plus on Windows XP
By Paulsa in forum Capturing and VCRReplies: 0Last Post: 3rd Apr 2008, 10:02
