I looked around on this forum, downloaded more stuff than I'll ever use,..
but I can't seem to find how to burn my BIN/CUE files to a svcd using something else than Toast. This can't be so difficult?!
I already got some usefull tips, but it seems still to complicated for me as I'm a newbie with no background on these things.
Although I understand what most terms mean by now, I still don't know how to install/use some things.. and I'm getting pretty spaced out trying and trying and trying..
I've got the FinkCommander, but how do you let it download and install things?
I even want to try burning trough the terminal (found out some commands, any idea where I can learn more?) with cdrecord or cdrdao but I'm not getting anywhere.
I have folders named cdrdoa-1.1.7, cdrdaoGUI, cdrtools-1.10; where should I put them and how are they used? What is the difference between cdrdao & cdrecord?
If I open the cdrdaoGUI and start the cdrdaoGUI.pbproj I can chose build
what opens up MMB; here I'm stuck because I've got some driver problem.
I feel pretty stupid asking this, but is this a hardware setting? How do i know what to choose, and is there any way of testing this?
(Note that my system is 10.1, so please no jaguar ways)
Don't really need all the answers, as long as I can burn i will be verry, verry happy!![]()
Forgive me for my newbieness..
I have a Mac Svcd burner that works nicely. It was written by a friend of mine and it does the job nicely with no toast needed
Send me your email and ill email it to you. If memory serves, its a small .sit file
You need to have the .cue and .bin files the program will do the rest. Its self explanatory.
my email is galactica@comcast.net ill send it to you when you reply. -
I have already sent a reply, but maybe you didn't get it.. so just to be sure here's my adres; frederik_frederickx@yahoo.com
Hope I'm not bugging you to much -just can't wait to try it!
Thanks a lot; a little help can sometimes give a great relief.
I had similar problems with MMB, until I realised that to get it working with my built in CD-RW/DVD-ROM combo drive under MMB/cdrdao I had to select the DVD-R device (i.e using IODVDServices instead of IOCompactDiscServices), even though I didn't have a DVD-R drive...
Then use the generic-mmc driver. -
!!!!!!!!!TO THOSE WHO REQUESTED THE MAC SVCD BURNER!!!!!!!!!!!!!!!!!!!!
Wow, I have gotten about 30 e-mails for requests of this program.
I will email those of you the program who have already sent me an email.
HOWEVER, please do not email me if you do not have OSX 10.2 installed. The program requires 10.2
Due to the demand, I am going to host a link where anyone can download this program. SO, I until I post that link, please continue to email me at galactica@comcast.net
Once the post is up, just click on the link.
Keep in mind, you must have 10.2 installed.
(All updates of 10.2.x will work as well)
Best requards
/Galactica -
cdrdao burns in disk-at-once (DAO) mode, and that's what you should use for burning (S)VCD at the command line. cdrecord has some limited support for DAO mode, but it's primarily a track-at-once program for burning ISO images.Originally Posted by Tamandua
If you want general information on using the terminal, pick up any introductory UNIX book. Mac OS X is different from most UNIX systems in some ways, but the general everyday commands you use to get around in the terminal should mostly be the same. -
Galactica, I'm interested in your software for burning SVCD's. I have a few questions. Since it requires bin/cue files how does it differ from "Missing Media Burner" ? A great burning program which also requires bin/cue files. A big stepup would be a program that would burn SVCD files from the mpeg2 file as is. However for what ever reason no one has come up with one. Why would one want to use your software over MMBurner? Thanks for any info.
Do you have an internal CD drive and an external CD-R(W) drive?
Well, MissingMediaBurner doesn't support this by itself until version 0.5. However, there's a catch - it doesn't work with Mac OS 10.1.x, only with 10.2. You'll want MissingMediaBurner 0.2. This is available at <www.angelfire.com/rnc>. But then, you don't get external support, but the internal version of CDRDAO does. This is how you get it to work with Mac OS 10.1.x:
Run the Media Burner normally. The terminal will come up and report something like this:
Welcome to Darwin!
cd /Users/nikki/Desktop/vcd\ folder/MissingMediaBurner.app/Contents/Resources/bin
./cdrdao write --device IOCompactDiscServices --driver generic-mmc --force --eject --speed 4 -v 2 /Users/nikki/Desktop/vcd\ folder/example\ test/PAL/videocd.cue
sw/bin/init.ch: No such file or directory.
[localhost:~] nikki% cd /Users/nikki/Desktop/vcd\ folder/MissingMediaBurner.app/Contents/Resources/bin
[localhost:Contents/Resources/bin] nikki% ./cdrdao write --device IOCompactDiscServices --driver generic-mmc --force --eject --speed 4 -v 2 /Users/nikki/Desktop/vcd\ folder/example\ test/PAL/videocd.cue
Cdrdao version 1.1.5 - (C) Andreas Mueller <andreas@daneb.de>
SCSI interface library - (C) Joerg Schilling
L-EC encoding library - (C) Heiko Eissfeldt
Paranoia DAE library - (C) Monty
Check http://cdrdao.sourceforge.net/drives.html#dt for current driver tables.
ERROR: Cannot open SCSI device 'IOCompactDiscServices': Unable to get plugin Interface: e00002c7
ERROR: Please use option '--device bus,id,lun', e.g. --device 0,6,0
ERROR: Cannot setup device IOCompactDiscServices.
Retype the ./cdrdao command except replace IOCompactDiscServices with IOCompactDiscServices/2. You should get something like this:
[localhost:Contents/Resources/bin] nikki% ./cdrdao write --device IOCompactDiscServices/2 --driver generic-mmc --eject --force --speed 2 -v 2 /Users/nikki/Desktop/vcd\ folder/example\ test/PAL/videocd.cue
Using libscg version 'schily-0.5'
IOCompactDiscServices/2: MATSHITA CD-RW CW-7586 Rev: 1.06
Using driver: Generic SCSI-3/MMC - Version 1.2 (options 0x0000)
Starting write resid: 110
at speed 2...
Pausing 10 seconds - hit CTRL-C to abort.
Process can be aborted with QUIT signal (usually CTRL-\).
WARNING: No super user permission to setup real time scheduling.
resid: 104
resid: 110
Executing power calibration...
Power calibration successful.
Writing track 01 (mode MODE2_RAW/MODE2_RAW)...
Writing track 02 (mode MODE2_RAW/MODE2_RAW)...
Wrote 1 of 1 MB (Buffer 100%).
Wrote 823 blocks. Buffer fill min 100%/max 100%.
Flushing cache...
Writing finished successfully.
?: Undefined error: 0. : scsi sendcmd: no error
CDB: 1E 00 00 00 00 00
status: 0x2 (CHECK CONDITION)
Sense Bytes:
Sense Key: 0xFFFFFFFF [], Segment 0
Sense Code: 0x00 Qual 0x00 (no additional sense information) Fru 0x0
Sense flags: Blk 0 (not valid)
cmd finished after 11.999s timeout 20s
ERROR: Cannot prevent/allow medium removal.
Well, hopefully you wont get the medium removal error. I didn't the second time.
Hope this helps.
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
Trying to burn an mkv with subtitles, but the subtitles don't burn properly
By geramul in forum Newbie / General discussionsReplies: 15Last Post: 1st Sep 2010, 20:12 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
