    Feb 2001
    Macondo, Puerto Rico
    Hi all,
    Do you know is there is a VHS cleaning device. I have found several VHS with fugus due to humidity and I don;t want to damage my vcr by playing them to do the capture.
    Regards,
    Jose Febus
  2. hi, there r another soln.
    buy a cassette rewinder(preferrably with a built in cleaning paper tip). rew/ffd the cassette few times. then put the cassette on a lamp shade(dont leave it for long, 3-4 minutes) the bulb should not touch the cassette & cover it with a dry cloth, then rew/ff again.
    or buy a dehumidifier if the humidity is very high in ur area.
    bye
