    Jan 2003
    So-cal
    I started making dvd's for friends and family but some who play the dvd's on thier PS2 are having problems, it either skips or one stops halfway through but when I play it on my set top dvd player no flaws at all. Instead of converting my avi's to mpeg2's at 100% quality 9.5 a sec shoud I do it at 80% about 7.5-8 megs a sec? Would that help? I was thinking mybe the bitrate was too high for the cheaper dvd players.
    Any input would be greatly appreciated.
  2. i thought cheaper dvd can play back alot higher bitrate then higher end dvds. atleast that's for svcd.
  3. Member DJRumpy's Avatar
    Dallas, Texas
    Check the PS2 specs. Anything else is just a guess. It could be anything from the media your using, to flaws in the mpeg.
    It sounds like your using CBR. Any particular reason?
    Impossible to see the future is. The Dark Side clouds everything...
    Jan 2003
    So-cal
    I dont even know what CBR means. I dont do the Tmpeg thing because the program is $50 and looks to complicated . IM getting good results so far just a couple people say the dvd skips or stops and goes to the menu sometimes in the PS2's. All though I I have not seen a DVD done through Tmpeg so I dont know the quality between mine and theirs would be.
