Hiya , I want to transfer some old movies to dvd-r , Im not sure how though I know Ive been told its easy to transfer vhs to vcd but I dont know how to do both and I want to transfer VHS to DVD is there a guide on this board? I couldn't seem to find it , would be awsome if someone can point out a guide. Thanks!
-Ryan
Slowly Im gettin this DVD-R stuff :)
There are basically three steps involved:
1. Capturing (from VHS to avi). You need some special HW to do this.
2. Editing and converting from avi to mpeg.Fast PC recommended
3. Authoring and burning. CD or DVD writer is essential.
For all these steps How-Tos and guides are availble (left side) -
thanks the hardware is a TV tunner right? can you point out which page the convert vhs to avi is? thanks
Slowly Im gettin this DVD-R stuff :) -
oh thank you! im so stupid lol
so I can convert it to mpeg then put it on dvd right?Slowly Im gettin this DVD-R stuff :) -
Exactly....so I can convert it to mpeg then put it on dvd right?
If you are looking for some reading here are a few links that can maybe clear some stuff up for you.....
http://www.adobe.com/products/premiere/pdfs/dvprimer.pdf
http://www.aluminumstudios.com/digitalvideo/basic/codec.html
If you use TMPGenc for encoding
http://dvd-hq.info/Compression.html -
Why are these How-Tos titled:
Capture
Convert
Author
and so on ...?
Are these captions so difficult to understand?`
If someone tells me: look at How-To Convert, would I look somewhere else? IMHO, if I see something, which says 'How To: Convert' in friendly letters on it, I'd expect some advice 'How to Convert' inside.Or am I so wrong?
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 02:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
