I have a mpg file formated for VCD but it's too big to burn on a single CD. When I split the file the sound not longer match the video part, why?
Is there a way to prevent this from happening? Settings?
Other programs that do a better job?
Thanks,
Roberto
seems to be a very common problem no matter what u use. one thing i have noticed from MY experience is that the MPEG tools in TMPGEnc v12 and v12a seem to be better than those in the later versions of TMPGEnc. you may wanna try cutting with one of these two older versions instead.
I have cut many NTSC mpegs vcd files with TMPGEnc with no audio/video sync problems. Under merge & cut I select mpeg 1 video cd. I am using TMPGEnc i.
<font size=-1>[ This Message was edited by: Lamont Cranston on 2001-09-05 15:37:09 ]</font>
Sound out of sync
By ssaamm in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2009, 10:19 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 07:58 -
Audio track out-of-sync with DivX/XviD media file after video was split
By robo5050 in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2008, 03:30 -
Sound when split screen used
By gmc9960 in forum EditingReplies: 0Last Post: 8th Feb 2008, 06:20 -
Sound out of sync
By bananadon in forum DVD RippingReplies: 9Last Post: 17th Oct 2007, 09:31
