Hi, I've been using an ADVC100 with my P-IV 2.53 running XP with no problem. Until tonight... Now, whenever I plug my ADVC100 into the 1394 port and power it up, the computer doesn't recgonize it is there. This may be significant: the ADVC100 powers up with both the analog and digital lights on the front panel lit up, and they stay lit up as long as there is power to the unit. I've tried all the usual things; booting with the AVDC plugged in and powered up, holding down the power switch for a minute or two, disablabling and re-enabling my 1394 port. I've tried the ADVC on more than one computer and it does the same on both other machines. The firewire cable works fine with other devices. Anyone else had this problem and if so, what was the fix?
Dave
try removing your 1394 device from your device manager in windows and boot the machine with the ADVC-100 plugged in and powered up. I had to do this when I first plugged the unit in and after windows re-installed the firewire device (h/w discovery on boot), I've had no issues with capturing since...
I'd also recommend checking out the forums over at Canopus if you haven't already. They have been a tremendous resource of troubleshooting issues!!!
-trill -
This happened to me the second time I used the unit. I called tech support, and they said it was a bad unit. I sent it back, and I'm waiting for a replacement.Originally Posted by kodi1996
I'm curious to know how long you had it before this happened. -
Salami,
My ADVC had this problem the first time I took it out of the box. Since I had been wanting a faster computer anyway, I convinced myself it was my computer and not the ADVC 100 (the things we tell ourselves to justify new toys!). So I went out and bought a new machine. The weird part...The ADVC100 worked! And it continued to work for about 3 weeks before the problem cameback. I just got off the phone with Canopus and they are said it needs to be replaced.
How to convert .SDV files to something WMM recognizes
By Carppacio in forum Newbie / General discussionsReplies: 0Last Post: 1st Dec 2010, 21:21 -
windows xp home computer no longer sees my 1TB usb-2 external hdd .. [RESOLVED]
By vhelp in forum ComputerReplies: 8Last Post: 28th Jan 2010, 14:00 -
My computer no longer recognizes my Panasonic mini-DV recorder
By mjv in forum Capturing and VCRReplies: 1Last Post: 23rd Dec 2009, 15:25 -
ffmpeg no longer recognizes new mkv files
By pliniusfogg in forum ffmpegX general discussionReplies: 2Last Post: 7th Jul 2009, 22:44 -
when captured avi goes over 4 gigs nothing recognizes it ?
By 99teggsr in forum Capturing and VCRReplies: 11Last Post: 28th Dec 2007, 23:00
