  1. How can I hurry up about 200 ms sound in comparision to video.
    There is a difference even if I re-encoded to wav and compress ones more to mp3. I use Tmpenc.
    Tnaks a lot
  2. Is it a constant audio difference or is there a gradual loss of audio sync? Scan the original file you are trying to encode with virtualdub (video - scan for bad frames) to check for bad frames.
  3. It was constant difference but I finally correct that with Virtual Dub option
    "Audio skew correction" adding a 700 ms delay.
    Koperek
