I'm new to this VCD stuff.
I am converting AVI files using TMPGEnc. Everytime it aborts stating problems with audio and it's always 98 or 99% complete. The resulting files play fine, but there's always a couple minutes at the end missing. I'm using the standard NTSC and PAL templates.
Any help would be greatly appreciated.
Results 1 to 13 of 13
Do you happen to be using the 12j version ? cause i've had something similar, it didn't say anything about Audio or Video, it just got to 99% and TMPGEnc gave a crash message, but the MPG is playable upto the last second, atleast in my case.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
i had a "similar" problem while batch encoding using vdub 12g, the first of two halfs of the movie "The Family Man". darn thing stopped at 99% with an application related page fault, leaving me with an MPEG that was ZERO in size!! pissed me off!! i restarted the batch encode using 12a instead and got thru both halfs with no problem.
I'm really starting to think 12j has some serious bugs! anyone else experiecing something similar ??
Best Regards,
Sefy Levy,
This happens regular, especially with badly cut movie parts. It seams that the audio is a different length than the video so TEMGEnc errors as it runs out of frames.
Not had it corrupt the mpeg, but have had the 99% error lots of times. Last 3 versions for me have been the same. -
TMPGenc j has been crashing on me lately...
And it did at one crash at 99%, but I got all of the mpeg except the last few seconds... -
Thanks for the version number advise. I'll check. It should be current because I downloaded the file about a week ago.
I'm now trying to encode the same movie that failed on me 3 times with 12j, i'm encoding it with 12a, if it doesn't crash, then it's 12j that is causing all these troubles.
Best Regards,
Sefy Levy,
I have been having 99% errors too. With 12i as well
as 12j. Toolame also seems to be a related crash issue,
but it crashes very early in the conversion.
I did find that encoding groups of "chapters" (I do 4
at a time) rather than larger 1gig+ files was much more
prone to error. I don't want to go back to 12a.... -
Interesting that 12j seems to be crashing on a lot of people. I just downloaded it, and will give it a go tonight on some Startrek Voyager VCD's
I never had a crash with 12i, so my system is very stable as far as TMPGEnc is concerned (about 80 VCD's, each with 4-6 parts have been done and no crashes attributed to TMPGEnc at all)
Dave -
I must have had a combination of problems. Installed 12j and tried a new movie. Worked fine this time. I think the suggestion of "badly cut movies" hold true. Some of those movies off Morpheus are pretty poor quality.
I don't think it's just badly cut movies, cause all the movies I encode are direct from a DVD rip, and i've not ever had a crash using any version of TMPGEnc untill this 12j, has anyone else had the problem with 12j using DVD rips or is everyone just encoding downloaded movies ?
Best Regards,
Sefy Levy,
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I don't think its just that location that has bad movies, it seams they are everywhere. It could be when it picks up from another user just now and then. But as long as you check the movie with a program like "vdub-mp3-freeze.exe" then at leased you can eliminate that problem. There is nothing worse than encoding 80% or more and getting a crash, better to check that out first.
Also I would think it might be a good idea to load the movie into Vdub, go to the end and mark that as the end, then click back one "keyframe" and mark that as the start, then cut that out, save a new AVI using "Direct stream" then the movie will end on a Keyframe, might just fix the 99% problem !
AvsToDVD aborts during finalisation
By alhenderson in forum Authoring (DVD)Replies: 25Last Post: 15th Jan 2013, 17:53 -
Unable to extract audio - BD-Rebuilder aborts
By mobie29 in forum Blu-ray RippingReplies: 4Last Post: 7th Apr 2011, 10:19 -
Capture aborts when media format changes
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 22nd May 2008, 18:09 -
TMPGEnc Plus won't complete batch jobs.
By Timex in forum Newbie / General discussionsReplies: 2Last Post: 7th Dec 2007, 00:13 -
Nero 7 Ultra Edition Aborts DVD to Burn
By uLmighty in forum Authoring (DVD)Replies: 5Last Post: 12th Aug 2007, 03:02
