Hey,
I am trying to link a video file (.mpg) with a audio file (.wav) and can load the .wav in little area that you load your files but can't link the two in the movie. Is it possible to use .wav's?
Brad
Are you saying that you want to add audio to a video file? If so, you have to put these together before you use it in dvd workshop. To do this you have to use the multiplex feature in tmpg. Go to file, mpeg tools, then simple multiplex, add the video and the audio. However, I think mpeg files can only be multiplexed with mp2 audio (not sure about this).
If you are saying that you want a video file (no attached audio) and an audio file playing in the background, just add the soundless video file and set the background music with the wav file.
Mp4, Aac & Wav Extraction
By mahendras in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2010, 09:27 -
mp2 & wav compatible DVD authorers?
By Bassquake in forum Authoring (DVD)Replies: 4Last Post: 2nd Feb 2009, 15:11 -
Dif / DV25 & Wav to MPEG (suitable for DVD burning)
By sevenleaf in forum Video ConversionReplies: 0Last Post: 21st Aug 2008, 05:33 -
Making an audio dvd with wav & mp3 files
By wwervd316 in forum AudioReplies: 1Last Post: 18th Mar 2008, 22:41 -
DVD Audio To .wav Sample Rate Question
By xtreme469 in forum AudioReplies: 3Last Post: 29th Sep 2007, 10:04
