  1. I want to resize my video to 512 X 384 and I want to include the subtitle with it instead of having to keep the subtitle file all the time.
    Anyone?
    thanks alot in advance
    Sorry .I forgot to mention...i KNOW how to convert/resize/re-encode.....but how do I do it WITH the subtitile?
    thanks alot
  2. Banned
    Dec 2002
    Somewhere I belong
    If you are making a vcd with subtitles,then follow this guide:
    https://www.videohelp.com/srtsubsvirtual.htm
    If you want to add the subttiles into the movie and have it just as a AVI movie,then follow the same guide but when instead of frameserving it,go to "File->Save as AVI
    You need also use a compression before saving the AVI,
    use video compression like DivX or xvid.
    And in the audio,use direct stream copy.
    But if you save it as a AVI,you then encode it so it will take some time and you will lose quality of the movie.
  3. oic
    thanks alot
    I'll try later in the afternoon,.......I have to college in awhile
