I have just finished a 24 hr encoding marathon of 352x 240 mpeg-1 in Tmpgenc. I used the 2-pass VBR method and aside from being a bit too large it works great. Now in order to squeeze it onto a CD (its VHS source after all) i want to edit it but every time I do the sound disappears?? I have tried M2-edit, Tmpgenc, mpeg2vcr and all do the same thing--edit the movie, drop the sound.
Anyone have any luck and can pass on how to edit a 2-pass Mpeg-1 VBR file? oh ya--I DO NOT want to reencode this thing unless I have no choice!
Thx
I guess as a follow up question--is anyone out there editing their 2-pass VBR Mpeg-1 movies? If so what programs are you using. If not--why am I the only one doing this
Unless I am putting a whole video on one disc, I use the source range settings in Tmpgenc to define the portion of the source file used. As well, I use the batch encode method which allows multiple encodes in sequence. In other words, I have no need to edit my Mpegs. Depending on your source file, there are other editors (such as Vdub for AVI's) which might help.
"Art is making something out of nothing and selling it." - Frank Zappa -
Thanks for the input but Vdub is out of the question--since I might just as well edit the original and then re-encode for the same amount of time (if there is a VCD god then he/she/it won't make me do that)
I just want to cut 5 minutes off the end of the file and preserve the sound and video quality.
Does powerdirector have 2 pass VBR?
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 24th Jul 2009, 23:49 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 03:55 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 11:16 -
DVDA 4 can do 2-pass VBR?
By itsme1 in forum Authoring (DVD)Replies: 4Last Post: 14th Jul 2007, 23:24 -
Need help with ffmpeg 2-pass VBR encoding
By SliderVF14 in forum Video ConversionReplies: 8Last Post: 14th May 2007, 18:03
