  1. Member wulf109's Avatar
    Jul 2002
    Is there any way to change an 0x81 audio stream to 0x80?? Many DVD's use 0x80 as the 448 bit audio stream and 0x81 as the 192 bit audio stream. I want to change it so that the 192 bit audio stream is the 0x80 audio stream.
  2. YOU CAN DO THIS AT RIPPING STAGE W/SMARTRIPPER
  3. Member wulf109's Avatar
    Jul 2002
    What I'm trying to do is convert TV episode disks with DVD2ONE and Make-It-Easy which requires keeping the original ifo file. I need to be able to change the original ifo file.
  4. I have done episode discs without keeping the original ifo. You can just rip the main vobs and then run ifoedit and have it create new ifos for you. Just make sure you have it create 1 PGC for you. Then run dvd2one and transcode the video down to 4.36 gb and burn away. Works great! I did Sanford & Son the Complete First Season this way 8)
