I have had no luck in getting the WinDvr to recognize the KWorld USB TV box. I am running it with the recommended SPCA506A drivers. As such, it shows the TV box as a camera, not a TV tuner. Are there other drivers available for this if it is in fact a driver problem, and if so, how do I get the computer to recognize them as appropriate for the hardware.
Thank you for your help.
tragatz@cox.net![]()
I solved the problem by unplugging the existing intel web cam. The tuner was recognized, then I was able to plug the webcam back in.
Problem solved.
Intervideo WinDVR 3 wont record more than 10 minutes
By goshtin in forum Capturing and VCRReplies: 1Last Post: 8th Feb 2012, 15:11 -
About windvr and easygrabber 2.0 capture.
By MidnightMike in forum Video Streaming DownloadingReplies: 3Last Post: 15th Dec 2010, 18:32 -
windvr 3 and no sound
By goodtilltomorrow in forum Capturing and VCRReplies: 6Last Post: 12th Oct 2008, 17:34 -
InterVideo WinDVR 3: "The specified capture format is not supported on
By SignedupGuest in forum Newbie / General discussionsReplies: 1Last Post: 17th Sep 2008, 20:01 -
WinDVR Input disappears while recording
By jacx3 in forum Capturing and VCRReplies: 2Last Post: 24th Feb 2008, 12:39
