I have an anime my friend gave me and the it was 5XX*4XX at 1200 bitrate and the quality didn't look as good as it should have so I ttok a peak in Gspot and this is what I got:
Gspot has found Microsoft MPEG-4 Video Codec V2 , which is installed on your system, and is a compatible with this format; based on that, the video should play fine
Direct show is apparantly able to play the file as well, though it have selected a different codec, the[b\ Microsoft MPEG-4 Video Decompresser, whose primary 4cc (MPG4)[/b] does not match the file's 4cc (MP42). This is because the codc claims to be able to decomprses 8 other formats besides MPG4, and this is format number three on that list.
This is usually not a problem, but under certain circumstances there maybe a preformance issue (qualtiy)
But it looks like i'm one of the those circumstances (sorry for the horrible spelling)
So i figured " well...the quality is there but it isn't showing it, lemme rip out the video and convert it in Vdub"
But the problem is that VDub gives me an error. How to get this file into divx 5.02? Thanks
You can change the fourcc code with this software.
Perhaps this will trick Vdub into opening it?
But watch out, it can be dangerous. Try it on a copy of the file.
What kind of screen should I get?
By vidds in forum Newbie / General discussionsReplies: 17Last Post: 13th Jun 2011, 21:49 -
what kind of protection is this?
By AaronDude in forum DVD RippingReplies: 0Last Post: 6th Jun 2011, 18:34 -
what is this for kind of codec.
By Cazz in forum Newbie / General discussionsReplies: 1Last Post: 12th May 2009, 16:18 -
What kind of driver are you?
By yoda313 in forum PollsReplies: 29Last Post: 18th Sep 2007, 11:26 -
What kind of gamer are you?
By yoda313 in forum PollsReplies: 21Last Post: 6th Aug 2007, 19:18
