TMPGEnc Plus 2.51 do not let me adjust bitrate.
I use project wizard but can not adjust the bitrate to fix my desire file size.
It was work before. Anyone know how can I fix it.
you need to make your own template. then you can adjust the birate. not sure why they did that for it was just fine the way it was. but thats what you need to do.
First select a template, then Click Load->extra->unlock, you should be able to change the bitrate in Setting now.
TMPGEnc Authoring Works - bitrate too high
By ecc in forum Authoring (DVD)Replies: 9Last Post: 19th Feb 2009, 14:06 -
TmpGenc Authoring Works 4 - how to set bitrate?
By mrhata in forum Authoring (DVD)Replies: 2Last Post: 18th Feb 2009, 01:40 -
TMPGEnc Xpress bitrate calculations are off
By Taeran in forum Video ConversionReplies: 3Last Post: 24th Sep 2008, 18:17 -
TMPGenc won't allow bitrate to go below 1600??
By bebopdeluxe in forum Video ConversionReplies: 3Last Post: 10th Aug 2007, 19:49 -
ISO advice on what bitrate I should use in TMPGEnc....
By RKelly in forum Video ConversionReplies: 4Last Post: 26th Jul 2007, 13:13
