I need a good way to estimate the file size when using 2pass VBR. If I use a standard bitrate calculator and plug that number into the avg. kbps field will I get an accurate file size? I can't use the TMPGEnc wizard because it won't allow estimation for 2pass VBR. I encoded two, similar lenght movies in 2pass VBR, with similar values and one movie was 1.3 gig., while the other was 935mb. WHAT'S UP WITH THAT!!!![]()
The file size estimator works fine in my version of Tmpgenc. Just select the type of disc you have (in the box) and adjust the average bitrate accordingly. Maybe you didn't input the disc type?
"Art is making something out of nothing and selling it." - Frank Zappa -
The bitrate calculators should be fine for either CBR or multiple pass VBR. They will not work for CQ_VBR thou.
As to why you got a 1.3gb vs. 985mb file??? I have no idea. I know that some recent (but not the newest) verisons of TMPGenc had a bug that if you were encoding MPEG1 the bitrate would be 1150kbit/s (VCD whitebook) no matter what you entered. But that wouldn't explain your results.
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 02:44 -
FFMPEG MPEG-2 VBR output size not coming out as expected
By DJRumpy in forum Video ConversionReplies: 1Last Post: 16th Sep 2009, 09:19 -
File sizes getting bigger with x264 2pass
By ivan_hoe in forum Video ConversionReplies: 6Last Post: 19th Apr 2009, 08:42 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 20:48 -
CBR vs VBR with same file size.
By PuzZLeR in forum Video ConversionReplies: 13Last Post: 18th Jun 2007, 01:47
