I have a Pinacel Studio 8 system in my pc with their card. capture and audio is ot of sync.
Two Questions
1. is their any other software that will work with this capture device.
2. What card is best for capture from VCR and Video 8 Camcorder.
may also want to be able to use USB and 1394 input for later.
Need Answer Soon i have had it with Sudio 8 software.
Jim
WinDVD Recorder will, you can download a trial here.
http://www.intervideo.com/jsp/Product_Profile.jsp?p=WinDVDRecorder -
I dont have the card or the software that you are talking about, but it sounds like the problem is systemic, meaning that it is probably something in the way your hardware/software is configured.
As far as compatible software(s), I personally use for real time capture, powervcrII and for avi to convert captures, IUVCR with the pegasys codec set to 18.
I'm assuming that you have checked for updated drivers and whatnot on the respective sites and for your motherboard. Are your system resources being taxed when you cap. Is the sync issue only at start up or during the entire cap. Are you losing frames in your cap, is the sync gradual or all over the board? -
I have checked for updates etc. Studio 8 web site is full of people with same problems, video, audio problems so that is why i want to get something that works. will try downloading suggested software.
Jim -
I bought the dc-10, which I believe was the pinnacle card and could NOT get it to work at all. A different between our systems is that my OS is XP and yours is 2000. If we are talking the same card, I returned the $100 card and bought myself the ATI tv tuner card and with iuvcr and powervcr II have been very happy with it.
I say that because I spent MANY hours farting with the card and finally just gave up. I am sure there are people out there that use it and it works faithfully, but my personal opinion is that unless your getting a higher end card, the ati tv wonder's seem to perform the same as other slightly higher and lower priced cards. Just an opinion...
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
A good Mic, Capture Card, and Video Editing Software.
By xSyndromex in forum Newbie / General discussionsReplies: 8Last Post: 18th Jan 2010, 15:38 -
Once again - Good capture card for beginner
By MillowQc in forum Newbie / General discussionsReplies: 0Last Post: 4th Aug 2009, 23:14 -
Good Card for Video Game capture
By npsken in forum Capturing and VCRReplies: 1Last Post: 6th Aug 2007, 08:55 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
