Hi there.. I've just finished ripping audio from several MP2's and converting it to AC3 format. I was able to mux the ac3 back into the original video, but now the sound is much softer- more quiet. I'm listening to these on just a 2-speaker setup, though I wouldn't figure that mattered.. Anyone have an idea as to why?
Butch
That is coz when you compress a sound file, you take out some of the audio information. With less information (the 'instruments that plays your music), of course it will sound softer.
I encode, therefore I am -
Really? I'd thought that the idea of compression would be to keep the exact same level of quality in a smaller file.. Kinda like a zip or rar file.. They're smaller than the files they hold, but when you decompress them they still output the same (bigger) files.. There's no quality loss then, right?
Butch -
Zip files are lossless compression. Almost all video and audio compressions are lossy compression algorithms. For instance, if you encode a CD to MP3 and then decode the MP3 back to WAV audio and burn it to a CD, the 2nd CD will be of lesser quality than the original.
Conversion to AC3 with freeware tools will always result in a loss of level.
This is due to a setting called the DOLBY DIALNORM setting.
This can only be tweaked to equal the level of your input MPEG file(or PCM) in the authoring environment. SCENERIST, CREATOR or FUSION have access to these settings, Ulead and Pinnacle do not.
To do this with freeware, just increase the level of the MPEG sample before conversion.
I've got a question about audio editing, like isolating certain sounds...
By darkzero297 in forum AudioReplies: 8Last Post: 9th Feb 2009, 20:34 -
Nero Vision 4 Audio Sounds Overdriven, Distorted
By norton833 in forum Authoring (DVD)Replies: 3Last Post: 12th Aug 2008, 17:23 -
Audio Sounds Muffled
By NBninja8 in forum Capturing and VCRReplies: 1Last Post: 25th Jan 2008, 23:53 -
DVD audio sounds high pitched
By nopulse in forum Newbie / General discussionsReplies: 3Last Post: 19th Nov 2007, 19:31 -
Newbie question about the audio sounds of my PC
By jeanpave in forum AudioReplies: 5Last Post: 12th Sep 2007, 00:32
