I am messing around with converting some DVDs (loading the IFO) to AVI. I am basically following Pinoy2201's Divx Newbie Guide but using DivX 5.03 and DVDx 2.1.
I was wondering if I tell DVDx to output the AC3 to a separate file, what program can I then use to put the audio back into the AVI? I am going to try VirtualDub and I read something about graphedit but if anyone has any pointers, I'd appreciate it.
Also, are there any special settings for DVDx when the source IFOs are the 16:9 version?
Thanks!
Mind Flayer
there is a ver. vdub that supports ac3,but i would just download nandub which is like vdub. http://hem.passagen.se/ohman123/?noframe
90% of dvd will be in 16:9 so the defaults should be ok?
The electronic components of the power part adopted a lot of Rubycons.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
