well i got a burner and i use nero and easy cd and loads more
but every time i burn its all nice and dandy
till it finishes and then i find that the cd is empty
Need more info. What are you trying to burn, what/which of nero's templates (if any) were you using, you say the CDR is empty? So there are NO files on it, but it has actually be burnt (ie. you didn't just run in test mode)? etc. etc. etc.
well i tired to burn wav's mp's bin's
everyting
i haved tried not only nero
the cd comes out blank
as it has never been burnt on -
if you take the same disc you burnt, and try to rewrite it, does it work?
i can think of 2 probable causes (other than your burner being borked)
you're burning in simulation mode
you arent finalising the session after it has completed
the other may be that you are using dodgy media....
Try a range of tools, in nero, using the medium info part, or using the toolkit, try the CD Info application which has a range of tests to check various parts of the burn.
Hope it helps
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15 -
Burner Slowdown
By Mitchum22 in forum DVD & Blu-ray WritersReplies: 13Last Post: 28th Jul 2007, 01:01 -
Needing a new Burner
By Burn it up in forum DVD & Blu-ray WritersReplies: 6Last Post: 21st Jul 2007, 23:52 -
Is it the scratches or my burner?
By LittleQueenie in forum DVD RippingReplies: 3Last Post: 1st Jun 2007, 01:35 -
After a new burner and media.
By SE14man in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2007, 11:03
