First Q:
Do Hi8 analog tapes have high enough quality to be burned as SuperVCD or should I digitize them on VCD?
I'm capturing with Marvel G400 TV using the Matrox MJPEG codec. I'm a PALviewer.
Second Q:
Which resolution should I chose: the highest possible (720x576) or will something lower do.
Third Q:
The resolution for SVCD seems strange. 480x576 gives a picture that is kinda squeezed in on left and right and streched out to the upper and lower. Is that normal. I thought the ratio had to be 4:3 while 480x576 is 5:6.
I hope someone can solve these for me.
JW
<font size=-1>[ This Message was edited by: Pompebled on 2001-09-05 07:31:14 ]</font>
RE 1:
Yes, Hi8 is supposed to be higher resolution than VCD.
RE 2:
Check the specification of your camera regarding the real resolution of the video. I think it is useless to capture at much higher. Mine can do 480 horisontal lines, therefore I capture at 640x480. 480x480 should do fine, though I want to have the 4:3 aspect ratio for editing.
RE 3:
There are picture (source) resolution and display resolution. SVCD source resolution is 480x480 NTSC and 480x576 PAL, however, when encoding you set the display resolution to 4:3 if you plan to view it on regular TV or PC monitor.
Hope this helps.
BeTa -
1. the order is; 8, high8, digitial 8
2. if your gonna capture for vcd, try to capture as close to vcd as you can. your capturing dvd resolution.
3. i think it's squished because your used to seeing 640 vertical lines.
Converting analog Video8 and Hi8 to digital
By ldemer in forum MacReplies: 14Last Post: 15th Dec 2022, 18:01 -
Converting Analog Hi8 tapes to Digital to PC
By Dicka24 in forum Capturing and VCRReplies: 9Last Post: 4th Jan 2011, 13:07 -
Sony Hi8 has been defective but want to play the Hi8 tape
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 22nd May 2009, 23:06 -
Analog to DV Tape vs. Analog directly to computer
By jlorelle in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 7th Sep 2008, 10:45 -
How to tell whether analog->DV video was originally Hi8 or Video8?
By Colmino in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 2nd Jun 2008, 21:06
