well i d/l a coupel of 805 mega bin files
and i boute a few 800 mega cd's
now i was told they would fit
but when i try and burn nero and 120% alcohol tell me the media isnt big enough what do i do?
Go into nero advanced options. check "enable overburn" (805 mb is a little bit too big for regular burn) Set the max overburn to 84 minutes.
insert 700 MB media (Vcd's can burn up to 800 or so MB on a 700 mb media, dont worry about it)
Then burn the bin in disk at once mode. -
10x mon
i just heard that cdrwin
takes the bin file and burns it by minutes not by mega
wonder if thats right
US mega millions - you in?
By yoda313 in forum Off topicReplies: 2Last Post: 1st Apr 2012, 08:40 -
Help with large TS file
By mejallen in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2010, 19:44 -
Help to compress large HD File
By camlachie in forum Video ConversionReplies: 10Last Post: 10th May 2009, 12:47 -
fitting file size to screen to play on standalone DVD
By Dolly in forum ffmpegX general discussionReplies: 7Last Post: 11th Jun 2008, 11:49 -
Large .dvr-ms file?
By ukcat in forum Newbie / General discussionsReplies: 2Last Post: 7th Sep 2007, 15:47
