Got a few 25 packs of Accu media off eBay. I've only openned one of the packs the first few disks worked fine, but now all I get is errors. I've tried to test everything else. I ran the sony test for my Sony DRU500 1.0f drive. No problems. I have my burning data on a separate HD w/ UDMA enabled. That HD also only has the burning files on it only. I'm using Instant VOB to burn to the disks. I use only 1.0x write speed and have been doing a simulation before write. Everything is fine until somewhere past the 75% mark on the disk. Then somwhere in that last 25% I get a write error.(In the simulation mode)
I suspected possible power issues (had a problem similar with a CD Burner before) so I removed all non essential devices/cards. (have a 350W PS so it shouldn't have any problems anyhow.
So I'm wondering are these Accu disk really that shit? What do people recommend for cheaper media?
-=| Felix |=-
I have the Sony and have used ACCU media with no problem.
http://www.cdrdvdrmedia.com/higqual47dvm6.html -
I have burned MANY ACCU disks and have never had a problem with them except for a few coasters which were from my error not the disk's.
Seems like the last 25% of the disks are unstable always giving me errors. I've tried with different data thinking might be that. Strange part is I can pop a -RW disc in there and works no problems. Must be the media. now I can't decide if I should sell the rest of my Accu discs or open them and take a chance.
-=| Felix |=-
vlc media player record problems
By deanst2 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jan 2016, 09:04 -
Problems with DivXland's media subtitler
By cevita in forum SubtitleReplies: 1Last Post: 29th Nov 2012, 20:58 -
Black Magic Media Express Problems
By Decerto_LethaL in forum Capturing and VCRReplies: 0Last Post: 13th Dec 2011, 09:39 -
problems ripping to Media Player ?!
By paulpeople2476 in forum Media Center PC / MediaCentersReplies: 3Last Post: 17th Jun 2009, 10:37 -
VLC Media player problems
By romanstopme in forum ComputerReplies: 7Last Post: 23rd Apr 2009, 17:31
