I'm trying to copy frank herbert's dune and put it on 2 disks, b/c it's 265 minutes. i want about 130 minutes on each disk, figured i could compress enough w/ dvd2one to do exactly that - split the movie on 2 disks.
if i use dvdxcopy, it will split it to 3 disks b/c the first disk is 2 layer and has 8 vob files worth of movie. the 2nd disk has only 4 vob files of movie.
i figured i could put the 12 vob files together then split it to 2 disks? i can't seem to do it, and i think there may be an easier way. here's what i'm doing:
1. extracting both disks d1 has 8 vob, and d2 has 4 vob.
2. delete ifo and bup files.
3. renamed the d2 vob files to VOB_01_04 through VOB_01_07
4. renamed the last 3 d1 vob files to VOB_01_01 through VOB_01_03 and put them in with disk 2's vobs
5. so now i have 7 sequentially numbered vob files in the folder (one thing i might mention is that vob 3 is only 800mb.)
6. i open ifoedit 0.91 and click on create ifos. selecting vob_01_01 as my first file. (this is the vob from the first disk)
7. after the 4 files are created, i close the program, reopen ifoedit, then click on get vts sectors. (i've also tried w/ this step omitted)
8. i open up my ifo file in powerdvd and the movie starts off at vob_01_04, the original start of disk 2. it's totally ignoring the fact that the other 3 vob files are in front of it.
9. it would be at this step that i would open ifoedit again, selecting the ifo, and clicking on vob extras. now that leaves me with a new set of vob files that when viewed indibidually work just fine, but again, the ifo file created for the new set ignores the parts from the 1st disk.
10. i even tried get vts sectors on the ifo created in part 9, but with the same outcome.
so does anybody have any idea how to fix this? i know people can add vob files on the end, but has anybody tried adding vob files to the front?
do i have to demux every vob so they are all small, then make them into 2gig files? something like that?
i've tried searching the forums and no luck.
Prior post today goes over the same issue. VOB limit is 10 (that's in theory 9+ GB). Try ripping to 2 GB VOB's or only 2 VOB's ( 1/disk ).
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
after ripping into 2gig vobs, i realized this movie was actually a miniseries (totally forgot, 3 episodes, 2 hrs each on sci-fi channel)
i ripped the 2 episodes from disk 1 and the final episode from disk 3 w/ no problem in 2 gig sizes w/ no problem.
now i just have to decide if i should just put on 3 disks, or try to use dvd2one for the first 2 episodes and just put the 3rd on on a 2nd disk.
thanks for that idea of 2 gigs, now i'll play around w/ it more. -
i figured i would just try putting all 265 min on one disk and see what the quality looked like.
so i ended up with 6 vob files, 2 for each episode
when i put them in the same folder, and numbered them sequentially, ifoedit created an ifo that was wrong
it put the "movie" in this order: ep1, ep3, ep2, then the first 2 chapters to ep2 at the end.
ep1 and 2 came from disk 1
ep 2 came from disk 2
when viewing the ifo in ifoedit, (where each break is, and lba is), the chapters correlate with the movie in the order i said above, but look like this:
1/1
1/2
1/3
1/19
1/1
1/2
1/25
2/1
2/3
2/4
2/22
i take it each is a chapter break (where you hit next on your controller)
1/25 and 2/22 are from disk 1.
why isn't ifoedit putting the movie in the order i put it in (ep 1-3)?????
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
DVD+R9 Double Layer first burn: problems with layer switch
By Edmund Blackadder in forum DVD RippingReplies: 400Last Post: 4th Oct 2009, 11:27 -
Sticky upate? When will Dual Layer DVDr disk be available
By JoeBolden in forum FeedbackReplies: 1Last Post: 11th Jun 2008, 03:54 -
Problems with Dual Layer disk burning.
By qaa in forum Newbie / General discussionsReplies: 19Last Post: 21st Apr 2008, 01:47 -
dvd9 to one disk dvdr
By mordor in forum DVD RippingReplies: 6Last Post: 27th Mar 2008, 01:44
