When I try and burn an mpeg 1 file on nero using the vcd section, more often than not it starts to burn the 'lead in' and the nothing more.
I encode my mpeg 1 files using TMPGenc and they seem they go to 100% complete, it's just they don't burn in nero.
Do you think it is :-
a) Nero
b) My computer
c) TMPGenc
Please help, as going through a lot of CDR's!!!!
I have encountered several of the same problems that you are having while using NEro, the best advice I could give you is that if you have access to another burner try installing Nero on that PC and doing it from there, I have a Gateway here that it won't work on, but on my other IBM it works fine as if nothing is wrong. By the way, make sure those CD-R's that you are throwing away aren't blank because I found that I could still use them and that nothing had actually been written on them when the mistakes in Nero happened. If the other computer suggestion doesn't work then try another VCD program like Easy CD creator 5 premium which I heard works very well
Tmpgenc dvd mpeg is not smart rendered by Nero
By perfection in forum Authoring (DVD)Replies: 3Last Post: 17th Dec 2008, 15:00 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 19:40 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 05:06
