Results 1 to 11 of 11
    Feb 2003
    Paris, France
    Hi,
    I gave 3 or 4 tries to Forty-Two with different DVD and I can't obtain an Avi file a size less than 700MB. I did the update, and now am running 1.02; that was suposed to clear the Divx (1CD) situation.
    But I gave a try with Citizen Kane (with subtitles) : the avi file works great, but its size is higher than 700MB (around 720MB)
    What do I do wrong ?
    Does any one know how to solve that situation ?
    thanks for answering...
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Why do you need it under 700mb? To get it on a cd? The reason I ask is because I've had Toast accept and burn disks that totalled more than 700mb. First give it a try and see if it accepts it.
    Feb 2003
    Paris, France
    I gave a try and Toast 5.2 didn't allow to burn the Avi file... that's the all point !
    I don't know what to do ...
  4. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    Best bet is to cut out some of the beginning and end crap
    20 megs is about the length of the credits and maybe a beginning shot of the producers and what not
    I usually have the same problem, but use quicktime to nibble away at the ends until its down to 698 (you need 2 megs for the desktop files unless you do an ISO disk)
    Hope this helps
    Best of luck to you
    Feb 2003
    Paris, France
    but why should I cut something that should be under 700MB in the first place ?
    I thought the phase before encoding was supposed to determine the ratio of encoding to make the file under 700MB (in the Divx (1CD) case)...
    I don't get it, really...
    I don't wan't to cut the studio logo, nor the end credits... I wan't the entire film...
    thanks anyway...
  6. Member galactica's Avatar
    Jan 2003
    Perhaps this will help you
    Since you dont want to clip the ends
    How to overburn a CD-r (up to 750megs) on a mac
    http://n.ethz.ch/student/guajanai/OverburnOnAMac.html
    Or investigate how to tone down the quality just a hare, since you are soo close to what you want
    Hope this helps
    Feb 2003
    Paris, France
    thanks a lot, Galactica...
    since I'm not that much into Terminal things I didn't quite follow that part... but thanks for trying to help me...
  8. Originally Posted by pilauh
    Hi,
    Actually, it was intended to *help* the situation. The 1CDR Divx option was a bad idea, but folks wanted it so we put it in. The basic reason why your movies aren't fitting on "1CD" is because the movie is *too long* or has *too much action* to compress to the size you want at the bitrate we chose.
    *Sooo* what we are doing in v1.5 is allowing you to use whatever bitrate you want for "1CDR" Divx movies. Get yourself a bitrate calculator and figure out how low you need to set the bitrate for your movie of x length to fit into y amount of space.
    Of course, in this enlighted day and age (on PCs anyway) most folks just bite the bullet and make 2 disk movies since 1CD-sized movies *always* end up looking soooo much worse than a split larger on, its not funny
    No matter what "motion vectors", how many passes, whatever...the data rate is just too low to get something really watchable and enjoyable.
    However, for those that "like this kind of thing" v1.5 lets you set the datarate as low as you like for 1CDR Divx mode.
    -K
    Feb 2003
    Paris, France
    thanks alot K. for taking time to reply,
    so, I'll wait 1.5 and keep my faith in your good work...
    (btw, nice to have a clear answer by developers themselves... GREAT ! )
    Keep up the good work, and when I'll find my use of Forty-Two clearly defined... I will surely donate !!!
    keep it up !
    pilauh
  10. Originally Posted by pilauh
    keep it up !
    pilauh
    making sure the developers are around to *get* your use clearly defined is probably a better way to go...
    -K
    Feb 2003
    Paris, France
    umm...
    excuse my poor english, the meaning is not what it was intended to be... in other words, great work you do, keep it up and stay that clever !
