Lot of us on this forum think that DVDMaestro is one of the most favored authoring tools.
Only thing that Maestro lacks is the ability to generate a menu back ground with thumb size images of the chapters for a quick & easy DVD authoring. And probably, a lot of us agree that this is the painful part in the whole DVD authoring process.
I was wondering if we could put together a tool to automatically generate menu background with thumb size images of the chapters.
At the minimum, the tool should do the following:
Input:
1. Accept a Jpeg/Bmp image for the Background.
2. Accept a List of MPEG or AVI files
Processing:
3. Extract first couple of frames as still image from each MPEG/AVI file.
4. Resize these still images to thumb size.
5. On the Background image (point 1), arrange the thumb size images.
Output:
6. Save this as JPEG or BMP.
Any Ideas?
Try DVD Menu Studio you can do a lot with it although it may require a little work to do what you are asking
http://www.ezdvdadvisor.com/public/796.cfmMichael
Learn to create DVDs the Ezway
DVD Related Question Post them at
www.EzDVDAdvisor.com
DVD Developers Community -
I did try DVD Menu Studio. I felt it was like a substute to Adobe Photoshop. I could be wrong. I didnt spend much time with it. Does it extract Images form MPEG files for thumb nails? What all points it can cover from my original post?
Video web page menu generation software?
By villaVideo in forum Newbie / General discussionsReplies: 5Last Post: 12th Jan 2012, 21:59 -
Tool for move in-out main movie from blu-ray files system. ( has menu )
By wisitch in forum Authoring (Blu-ray)Replies: 1Last Post: 10th Mar 2011, 05:03 -
Lost Generation
By freebird73717 in forum Off topicReplies: 0Last Post: 7th Aug 2009, 09:35 -
Deinterlacing menu conflicts within DVdate tool
By Pierre1 in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2009, 08:43 -
oneclick tool to convert avi with 2 audio tracks to episodic DVD with menu
By ajamarkova in forum Video ConversionReplies: 3Last Post: 12th Mar 2008, 20:50
