okay i download ghost ship on a dvd rip and the picture is fooked all green n black the sound is there but the screen is green it sumtimes comes on the picture but its blocked cant harldy see and thing can any 1 help me sort this problem out i think i have every codec
please help me
thanks in addvanced
Darren
Results 1 to 15 of 15
thanks cheers
but i installed all them and tempgenc wont work....ehyd this?
Did you try the 4CC changer?. That worked every time for me. I can let you know exactly what I used if you are still struggling.
Please cos i dunno how the hell i install ffmpeg-0.4.6 lol so something easy i need thios ghost ship to work lol and tempgenc qont work any more pissing me off lol cheers
Just try this, see if it works for you.
D/L 4CC changer (It's tiny) and import your XviD then in the bottom pane type divx
To make a copy of your file 1st is a good idea.
All I can say is it works for me...........give it a go mate.
where do i download this 4CC changer ? cos it sounds good lol thanks m8
http://www.divx-digest.com/software/avifourcc.html
Also make sure you have the right codecs, Nimo should do it. -
yeah it worked mint THANKS "ABAB" also tryed it on gangs of new york the dvd rip one but that still wont encode it also goes upside down when i encdoe it thorugh nero plus cd2 is 2 big for the cd any helps on that so i can encode it 2 a mpg so i can whatch it grrrr @ these bloody movies lol
Your'e welcome.
I'm not sure I understand your other problem though. If you post in a bit more detail I'm sure It'll get sorted out. Have you set Nero to overburn?
(99 min Cds are cool if you want to get a bit more on each CD, I use them a lot).
I'm rambling now......
Later -
well nero burning rom ok.. i ran gangs og new york the dvd rip one though nero yes i hav set it 2 overwrite
me use 99mins cd all time
but gangs of new york cd2 wont copy or encode to MPG if i encode it the mouths dont macth when there talk dam sick of this lol peein me off must b another way some how.
Did you extract the audio from the video first?.
I'm assuming you D/L'd the film as two different files and then tried burning each of them onto a disc.........If so why don't you join them together first with V Dub then process the film with TMPG enc'. That way you can set the file size for each disc and guarantee it will fit. -
sorted it now m8
thanks to you cheers your the best thanks
avi.Net Problem: Not producing an .avi file
By Johnathan K in forum Newbie / General discussionsReplies: 10Last Post: 5th Feb 2011, 16:22 -
Got a really annoying problem, avi sync problem
By burnleylad in forum Newbie / General discussionsReplies: 10Last Post: 8th Apr 2010, 11:31 -
lagarith avi to xvid avi - problem
By phpmysql348 in forum EditingReplies: 1Last Post: 23rd May 2008, 13:15 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 10:57
