  1. I have a 20 mb mpeg1 movie file, and I need to reduce the file size.
    I have been told if I convert it to avi then this will greatly reduce the size (I dont want to sacrifice a lot of quality though).
    I tried using Virtualdub, but the file size was bigger than b4.
    Can anyone give me a simple program, that will reduce the file size, and output an avi which will play on anyones computer (no crazy codecs which have to be installed)
    thx
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    VDub with DivX compression ought to give you smaller size than the corresponding MPEG. If "anyone" has DivX codecs installd - who can tell?
    /Mats
  3. what version of divX?
    And any suggestions for the audio? should it be compressed to mp3?
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    For DivX some say 3, some say 5, none say 4.
    MP3 is great for audio. Other possibilities is AC3 (and raw PCM, but that's not that efficient...)
    /Mats
  5. if your gonna ancode to a compressed avi then you will need that codec on yer m8s comp aswell, but and mpg/mpeg file should play, fine
    is the best quality needed if not have a look at my help file
    http://www.data-uca.150m.com/vcdencoding.doc
    might help
