Hello there,
I am attempting to rip a dvd using dvdx and the panasonic plugin. Everything is set up correctly. I am working from a guide on this site. I set all of the settings exactly the same. However when I click on encode it says that it is buffering counts up to 10mb and then crashes.
Does anyone know how I can remedy this ?.
I've never used any audio plug-ins but I would select Save Your Harddrive/Location/*Hard disk* instead of Ram,if that doesn't work reinstall plug-in and DVDx.
I have also had problems using the panasonic plugin with DVDx. It encodes about 6 frames then stops. If anyone has any suggestions give us a holler.
??panasonic plugin ??
I've never had success using the plugin, but get good results without it!.
AVIdemux keeps crashing
By gastrof in forum Newbie / General discussionsReplies: 2Last Post: 31st Jan 2012, 14:32 -
MeGUI crashing
By socrates in forum Video ConversionReplies: 0Last Post: 10th May 2011, 05:49 -
x264 keeps crashing
By MR 3 in forum Video ConversionReplies: 6Last Post: 17th Jan 2010, 15:29 -
My Avidemux Is Crashing
By bigman70 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2009, 12:54 -
Ulead crashing
By chewie8008 in forum Authoring (DVD)Replies: 5Last Post: 12th May 2007, 09:57
