    Nov 2002
    Australia
    Hi,
    Quick question -
    I've got some mpeg2 files that I encoded from some captures I did as huffyuv. I burned them onto a DVD-R but when I play the disk, the movement is all jumpy. I'm guessing this is due to having the wrong field first for the interlacing, and that I probably should have used the other when I encoded it in TMPGEnc.
    So, is there an easy way to "fix" these mpeg2 files to change the field order?
    Thanks.
    Redding, California
    blahski
    If it's a field order problem then there is no easy to fix it. Re-encode with TMPGEnc using the reverse field order. If you use the wizard to detect the proper field order then it should detect the proper field order to encode.
    Chas
    Aug 2001
    Finland
    I believe you can fix the field order with pulldown.exe (but I haven't tried it myself)
