I have a question about DVDit!. When dragging chapter points onto a menu, is there anyway to change the style of the "button" it creates? It puts a capture of the frame, which I want, but it has "raised" 3D look to the capture. I want just a plain frame capture for the button. Can this be changed in the setup or anything?
Richard
No it can't be changed in the settings but you can create custom buttons and link the chapter point to them
Buttons should be large enough to be easily visible to the viewer. You should make your buttons at least 72×60 pixels, or 300
×80 for larger buttons. You can scale a button smaller
in DVDit! without loss of quality, but if you make a small button much larger, you lose resolution.Michael
Learn to create DVDs the Ezway
DVD Related Question Post them at
www.EzDVDAdvisor.com
DVD Developers Community -
Thanks for the reply. So, I have to create a button that has a still image from each chapter and link to that?
Richard
subtitles with DVDit 6 PRO
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2010, 13:51 -
Replacement for DVDit Pro HD 6.3 Final
By GrampaD in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Oct 2009, 11:04 -
Subtitle Sync Problems in DVDit Pro
By aquaorbis in forum SubtitleReplies: 0Last Post: 5th May 2009, 22:40 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 01:08 -
DVDit Pro HD and Sript error in activation
By arturjose in forum Authoring (DVD)Replies: 1Last Post: 19th Nov 2007, 00:51
