Hi All,
I need to convert several VHS to DVD and when trying to capture at 720x480 @ 4000 I get artifacts. Will 352 x 480 @ 6500 look better?
Regards,
Jose Febus
At 352x480, never capture more than 4900kbps. Since the DVD maximum is 720x480 @ 9800kbps, with half a frame you get maximum possible quality at 4900. Any higher bitrate at that resolution is 100% wasted space.Originally Posted by jfebus
However you will get even better quality capturing to DV-AVI, Huffy, or straight AVI, at 352x480, and then converting to mpeg2 with TMPGenc @ 4900 peak VBR (4900/3600/2000 ought to be close to optimal).
4000 is very low for 720x480 from VHS because that sort of frame size will overemphasize all the artifacting from the tape... a higher bitrate is needed to sink them "into the background". Even sending VHS through DV-AVI firewire, this is very visible - the "wasted information" of the large frame is quite apparent. When you're dealing with a VHS source, it's fairly safe to make your final compresses all at 352x480, 4900/3600/2000, and use the CQ of 100 if you are using TMPGenc's Automatic-CQ-VBR.-MPB/AZ
Converting 720x480 to 352x480
By Regor21 in forum Video ConversionReplies: 8Last Post: 9th Mar 2011, 11:34 -
Bitrate 720x480 vs 352x480 concept question
By CaZeek in forum Capturing and VCRReplies: 15Last Post: 8th Oct 2010, 13:08 -
How to patch 352x480 MPEG-2 to 720x480
By moxiecat in forum Video ConversionReplies: 1Last Post: 1st Mar 2010, 14:43 -
720x480 or 352x480 ?
By StoneColdWhat in forum Video ConversionReplies: 7Last Post: 7th Aug 2009, 09:16 -
VHS to DVD resize 640x480 or 720x480
By opti280 in forum Authoring (DVD)Replies: 2Last Post: 26th Feb 2008, 19:43
