I use Premier 6.02 and also tried 6.5. When playing on Computer I also can see the movie on tha Sony PC9 camcorder.
When export to tape and mark the activate recording deck. The camcorder starts rec and its only blue screen. Some times it comes a picture.
When start again to export to tape and unmark the activate recording deck. Then themovie cames om the lcd on the camcorder. Strange? Then when puch the rec back on the camera. It put the movie on the memory stick(ship).
What is the problem?
Results 1 to 9 of 9
Can anyone help me? I dont understand this. Someone have a god idea who i can try out?
You are pressing on the wrong record button. There is two recording buttons. One that records on the memory stick and another one that will record on the DV tape. Use the other one. I think that the other one is opposite the lcd screen. Don't forget that you must disable DV out in the camcorder's menu.
I have only one rec botton. But i have to swits between Camera and memory.
But when play back i use VCR. Then i cant use rec. Only When start to export to tape and unmark the activate recording deck. Then it works for memorystick.
A/V to DV is off in the camara menu.
The camera capturing good. When play back. export to tape. The LCD on camera is black for some seconds when starts rec. The it is blue. (timer rolling). sometimes it cames ut an picture in the LCD and when play after i got this on tape. -
Your camcorder is different than mine. Follow page 90 of your manual (below):
http://www.henrys.com/manuals/sony/DCR-PC9(en).pdf -
I tryed the manual way. Start play in premier and manual rec. Sometime is goes great, somtime it is only blue. And the same movie was playing (50 second). And export to tape with the activate recording deck is good and sometimes blue.
But i have used this camera before whitout problem. I wonder if it could be the servicepack1 for winXP pro. -
Try resetting your computer right before your ready to export your video back to you computer. It worked for me.
Perhaps the cabel. But has not moving the camera when rec and play. It is on the same plase.
Restarting the computer? Not helps
CS 5.5.2 fails to export HDV footage to tape/perplexed
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 6Last Post: 19th Apr 2012, 22:41 -
XH-A1 vs HV-30 HDV export to tape results/Which model is best?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 3Last Post: 23rd Aug 2010, 22:33 -
Can I export edited Movies back to DV tape directly?
By Yim in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 18th Aug 2010, 17:03 -
CS3 HDV Export to tape marathon/firewire nightmare
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 2nd Aug 2010, 12:34 -
what is wrong with this tape?
By thegreatbear in forum RestorationReplies: 2Last Post: 14th Mar 2008, 00:00
