Newbie Here,
Hello, I have a question about Dvd ripping. I used the DVD Decrypter and ripped the following files to my assigned folder on my hard drive:
PLS file 1kb
DVD video 1kb
Winrar archive 4,194,302kb
I01 File 63,906
MDS File 5kb
Im not sure which one I should use to write with. Also should I put the blank DVD-r in my cd burner or in my DVD rom (not a writer)? Is it possible to turn this file to a SVCD?
Thanks in advanced
Take a look at the "DVD Rip" faqs to the left. As an intro:
You can't burn a DVDR with a CDR drive.
You can't read a DVD on/with a CD-DOM drive
An 80min CDR holds 800MB of MPEG data, x(S)VCD
A DVDR holds 4.3/4.7GB of data
TMPGenc can be downloaded for free, CCE cost much money -
Thanks...What is TMPGenc and what will I need it for? I see you said I should get it.
Hi jaybird,you appear to be using dvd decrypter in iso mode judging by the files you have there,if you have a dvd rewriter you would select iso write in dvd decrypter to write the largest of those files [4,194] back to a blank dvdr this would then put the full film onto the blank.Originally Posted by jay_bird100
Not to be rude but you clearly haven't read the guides to the left. It's all explained there.
TMPGenc is a program to encode MPEG1 and MPEG2 files (video, audio or both). It's freeware (or mostly so). Take a look at:
https://www.videohelp.com/sefy/?id=ClassicalGuide.html
That's a good place to start. -
Thanks Vejita-sama your not being rude. I did read to the left thats how I got here. I always was under the impressions that forums are to help clarifi what you dont understand. This is what I read https://www.videohelp.com/forum/userguides/141024.php
Beintot this is telling me to use ISO mode and I do not have a DVD writer. I was under the impression I did not need one. Please Help.
First Timer..CPU Build Help.
By Texxas_Boy in forum ComputerReplies: 23Last Post: 20th Feb 2012, 21:20 -
LG DVB-T HDD/DVD Recorder Model RH2T80 - Timer Recording Problem
By KillrByte in forum DVD & Blu-ray RecordersReplies: 10Last Post: 30th Apr 2009, 22:20 -
Timer controlled DVD player?
By that Todd guy in forum DVD & Blu-ray PlayersReplies: 1Last Post: 7th Aug 2007, 13:16 -
How do you preset timer on DVD player/recorder LG RC6821W
By download in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Jun 2007, 13:39 -
Help with Timer in Sony Vegas 6.0
By petersju in forum EditingReplies: 1Last Post: 11th Jun 2007, 20:54
