hi e1 ,just done a backup of black hawk down using DATAWRITE DVDS 2x ,put it in my sony 305 and it plays up tp 124 mins then stops. the whole movie is on the dvd because i checked it on the pc. plz help ?
THX M8s
One word: MEDIA
Some of the media out there has problems when the video gets close to the edge.
DVD2ONE will shrink the files down, but it'll will fill the DVD out.
There's a free add-on floating (make-it-easy), made to increase the size of the VOBs prior to passing it thru DVD2ONE, so you can actually add the menus and extras. But you can use it to increase say by about 500 Megs the original VOBs, then pass it thru DVD2ONE, and finally remove the extra stuff added. The resulting file will be about 350Megs smaller or so and therefore not hit the outer edge.
From what other people are saying, Ritek media seems to be good for video. I'm currently testing Princo DVD+RW and definetly has this problem.
My .02...
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 02:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 10:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 10:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 06:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 16:11
