OK I'm using XP SP1, dvdXcopy 1.41, and Nero 5.5.10.7. Here is the wierdness. I'll use Bourne Identity for an example. I back the DVD up using dvdXcopy, and cancel it when it asks to burn. I then use vobrater and ifoedit to pull the nag screens out, I then burn with Nero (I just step through the Wizard). This makes a great copy that plays on my set top DVD player. Only bad thing is, my computer won't read or play the dvd-r. Is this normal?
What speed do you use to burn these DVD-r's?
If you are burning at 2x, try to burn one at 1x and see if it plays in your computer now! -
Well that's indeed a strange thing. I had it the other way: they worked on my computer and not on a Denon DVD player, but played on a Pioneer and Philips DVD Player.
It's not normal (i think) but it could be a DVD-R problem. Does this always happen with the DVD-R media you are ussing?
Or it's Nero... or something else....
I use record Now for the Burning
HDD/DVD recoder doesn't record or play dvds
By maybell in forum DVD & Blu-ray RecordersReplies: 5Last Post: 1st Mar 2010, 14:09 -
Will 720p record on standard dvd and play in HD on Blueray?
By jimdevo in forum Newbie / General discussionsReplies: 15Last Post: 14th Feb 2010, 14:15 -
Stand Alone DVD record Won't Play on PC?
By rkersh409 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 26th Jan 2010, 13:23 -
If I record in Widescreen 16:9, how will a DVD play on a Standard 4:3 TV?
By syberkill in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 3rd Jun 2008, 11:03 -
HELP: Looking for a GOOD DVD VHS combo - Don't need to record just play...
By UNOWEN in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Sep 2007, 12:24
