    Aug 2002
    England
    Hi
    I am presently capturing at 1/2 DVD PAL. With WinDVR2.
    Can anyone tell me the optimum gop and motion settings within the advanced video tab??
    Cheers
    Fozzee
    Dec 2002
    West Coast
    "I am presently capturing at 1/2 DVD PAL. With WinDVR2.
    this is what I have under the advanced tab.
    GOP-15
    sub gop-3
    Hor-4
    Vert-4
    BitRate-3600
    Aug 2002
    England
    Cheers
    Will capturing at a higher bitrate help when I encode the video down.
    My DVD player will only play CVD under 3000 bitrate.
    Fozzee
  4. A lot depends on what authoring software you are using and its requirement for Audio and Video. I set up my profiles based on what my authoring software requires.
    Dec 2002
    West Coast
    Absolutely!
    I have a rule of thumb that my captures need to be at least twice
    my authored bitrate.
    But I guess this would also depend on your hardware capabilities.
    Presently I can't capture above
    a 3000 bitrate without problems,
    but that's ok since I'm only
    using it to Tmpgenc down to vcd's.
    Still it bugs me, I know my computer should do better.
  6. Has anyone tested how motion settings affect quality? I have mine set at 12. Would 16 be better or is 8 or 4?
