I have no idea what's happening here, seems like lately, all my movies encoded result being out of synch....Aware of the fact that WMP does a great job in keeping movies synched, I test all my movies by playing them in VirtualDub and I know that the source avi file is OK.
I follow the all in one quide AVI to VCD or SVCD to the letter, and the resulting mpg file is out of synch even in WMP.
I am running
ATHLON 1600 XP
WIN XP
512 ram
I have installed
DIVX 3,4 & 5.03 codecs
XVID
AC3 filter
SVCD Plugin for WMP
I extract the audio to wav with virtualdub
audio --> no compression --> 44100.....save wav
TMPGENC
-Select the Video, Audio Source and Output name
-Go to Setting -->
--Video
--Rate Control Mode "2 Pass VBR"
--Motion Precision "Highest Quality"
---Advanced
---Full Screen (keep aspect ratio)
---Source Range
I encode it and the resulting mpg is out of synch....
what could I be doing wrong???
Also, since I have the same problem with XVID files, here are my TMPGenc settings....how come I don't see all the ones posted on the guide???
AVI2(openDML) File Reader----------0
BMP/PPM/TGA/JPG File Reader-------0
Wave File Reader----------------------0
TMPGENC Project File Reader 2.52---0
DirectShow Multimedia File Reader--- -1
AVI VFW compatibility reader--------- -2 -
most likely your audio is recorded with a variable bit rate (vbr)
when you open in vdub check audio then go to full processing mode
then go to aduio again and check conversion, then check 44100, 16 bit stereo and high quality THEN go to file and save wav. if your audio is not ac3 then it will be in synch. If it is ac3 then you need to convert to wav using headache or something. Use audio dierect stream copy then sav wav but change the extension to .ac3 instead of .wav. then convert with headac3he
good luck
Best app for HD-DVD to mkv conversion? With resulting file size around 4gb
By AndyD in forum Blu-ray RippingReplies: 1Last Post: 7th Apr 2009, 08:46 -
WMV Conversion to AVI resulting in poorer colors
By timmer545 in forum Video ConversionReplies: 2Last Post: 27th Mar 2008, 02:57 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 13th Jan 2008, 00:47 -
WMV Conversion to Xvid - Audio Synch Problems Again
By TonyRomo1227 in forum Video ConversionReplies: 10Last Post: 6th Aug 2007, 17:32 -
1h40min movies became 50min movies after conversion
By oediv in forum ffmpegX general discussionReplies: 1Last Post: 31st Jul 2007, 15:13
