  1. Just wondering...If I rip a DVD (9) to two DVD-R, using DVD Decrypter and ifoedit...
    If I afterwards think: Hell, why didnt I used CCE or DVD2one and made a 1 DVD-R backup instead..
    Is it possible to take the 2 DVD-R backups and convert them to a 1 DVD-R backup..?
    Hope you get my meaning, my english is far from perfect..
    Thanks in advance for any answer..
    yes, that is possible, you would rip both of them, then follow the instructions for ripping "episodic dvds" - it will somehow involve renaming some of the vobs and using ifoedit (don't worry, it's easy)
    here's a link
    https://www.videohelp.com/forum/userguides/141975.php
    and I have seen other guides posted in the forums which might be simpler!
    ZZ
    Oct 2002
    INdiana
    Yes, i've done TICKER with Steven Seagal. Originally i split it to 2 dvdrs. I went back and ripped each disc to its own folder on the HD. I renamed the VTS files on disc2 and dragged them over to disc1 folder. Choose GET SECTORS and then used DVD2one to shrink it down. All plays fine and looks the same. Only problem is that i cant select any chapters on the VTS files i transferred over - like skipping to the next chapter.
