I am trying to convert divx to VCD or SVCD, whatever. And everytime I select 29.97 fps it then says in the terminal that "FPS is 30000" and then my video runs faster.
I have tried using the qt decode, no avail
I have tried using the mplayer, it says that it cant find the ".conf" file.
I have tried using neither of them, still 30000!!!
WTF!
The only time the at the FPS is ever right is when I do a VOB to "something." The VOBS are always fine, everything else is too fast. HELP!!!!!
[*]_BonKer$_[*]
I get a similar result to you Bonkers! javascript:emoticon('
I am trying to get from a NSTC VOB to PAL VCD but the video is like a rocket and the sound is fast as well. I also tried several divx avi's as well and tried to make them PAL VCD's but here the sound was great but the video was going way too fast.
I didn't change the video bitrate at the front even though, for the vob at lleast I wanted 3 CDS. The audio settings I didn't touch either. I did try disabling QT decode, no avail. Turned off bicubic scaling and VOB letterbox as well, no avail.
Major, I hope you are tuning in, we need some help here. I tried to send you a email direct about this but the mail bounced. -
Dude, i think i figured it out. I dont know why but if you click the 3:2 pulldown it works.
I tried a one minute test clip and everything seemed to be in order for that one minute. With out the 3:2 pulldown checked it would be out of sync within seconds.
Goodluck.[*]_BonKer$_[*] -
Nice try Bonkers but I still could get it to work. I tried to go from the NTSC VOB to PAL VCD, used the pull-down for 3:2 and go audio way off. Though the video seems fine and the audio was ok, just miles apart.
I tried the latest ffmpeg version g. Still no luck. any other suggestions??????
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 05:40 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 22:42 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 04:53 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 15:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17
![Computer details: Macintosh OS X.2.2
500 MHz PBG4 [1st Gen]
20 int / 120 ext
512 MB
Firewire
Sony DVP-NS715p
None
Internal
Pioneer DVR-104
Pioneer DVR-104
G4
Comp](/images/buttons/computer.gif)
![Send a message via AIM to [*]_BonKerS_[*]](images/misc/im_aim.gif)
