If i'm making a SVCD the default SVCD VBR quality is 6... if i set to 3 for example.... that means better quality or worse, should i set the handle for a higher number like 10?
The default custom rate for SVCD format is 2500... a higher number is for better? this option has a limit depending the format you're selecting?
And how can i burn these files with toast titanium in os 10.2?
i used vcd toolsX to make .img files from each file and also gave me a .toc. i tried to burn them in toast with multitrack XA format, as said in the vcd toolsX, and said couldn't get the table of contents .toc ? what i'm doing wrong?
I also tried to make .bin format, but the movie looks like shit and there were no subtitles either, and what should i do with .cue file, this thing is important for anything?
if you could give me a good parameter for SVCD, i want to make a 2 hour movie in 2 discs.
Thanks for everything
did my answers to your private messages help?
let me know -
Hey Galactica!
thanks very much for your info.
there was something you forgot to tell me about svcd, but i've already checked out on your post to squeed.
SVCD 3500 custom rate, VBR 3... that all i need as an example for a good quality SVCD. And about VLC to test my SVCD's... i've already downloaded, so thanks again my friend.
Question about Bit Rate and Quality
By T375 in forum Newbie / General discussionsReplies: 4Last Post: 20th Sep 2010, 09:31 -
Bit Rate Vs Quality
By kashif71 in forum Video ConversionReplies: 20Last Post: 21st May 2010, 00:19 -
How do I encode VBR to CBR without losing quality?
By rocky12 in forum AudioReplies: 7Last Post: 1st Oct 2008, 11:59 -
Tmpgenc DVD Author 3 Custom Background Quality?
By haym in forum Authoring (DVD)Replies: 1Last Post: 29th Jul 2008, 18:49 -
Is higher bit rate = better quality??
By imdaman in forum DVD RippingReplies: 5Last Post: 13th Sep 2007, 07:37
