ok im new at this dvd authoring stuff but i have a problem. i am trying to make a dvd from a divx file. first i encoded an *.m2v file using TMPGEnc and then made a wav file using virtualdub. last i used ifoedit to author the dvd to my VIDEO_TS folder. the problem is when i go to burn using nero, my VIDEO_TS folder is way to big to fit on the dvd. so is there anyway i can make this smallercuz i need this to fit on the dvd+r.
the m2v file is 3.86 gigs
the wav file is 1.08 gigs
and the video_ts folder is 5.05 gigs
thanks
Justin
:agree: -
Transcode the video using TMPG/ReMPEG/CCE, you just put the bitrate to high which will give a larger file size
Or convert the wav to mp2 with besweet,tmpgenc,toolame.
DVD WAV(48khz) is about 12 mb/minute while mp2,ac3 is about 2-4 mb/minute. -
thanks for all the replys. i converted wav to ac3 and it fit perfectly thanks guys
Justin
:agree:
VIDEO_TS 7GB to VIDEO_TS 4GB
By klemyz in forum ffmpegX general discussionReplies: 2Last Post: 9th Dec 2009, 12:43 -
VIDEO_TS to AVI and (maybe) back to VIDEO_TS
By macbuz in forum MacReplies: 2Last Post: 16th Jan 2009, 19:40 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 29th Feb 2008, 23:51 -
FAVC - Missing VIDEO_TS.bup, VTS_01_0, VTS_01_0.BUP, VIDEO_TS (.vob)
By Brent.M in forum Newbie / General discussionsReplies: 14Last Post: 8th Feb 2008, 07:47 -
VIDEO_TS to mpg to VIDEO_TS
By Mållgan in forum EditingReplies: 9Last Post: 29th Jan 2008, 14:53
