Has anyone come acrosss this before. Ripped MIB2 using smartripper then usinf the m2v and ac3 files tried to join them using spruceup. Everything seemed to be going fine until 97% of the way through the ac3 file I got the following error.
"inconsistent bitrates were found among the audio frames. Bitrate should be consistent throughout the stream"
I tried re-ripping the film and even tried to use the 2 channel audio but got the same error message ? Any ideas
yop, spruce has nothing to do with that, it is the AC3 that is ,like it says, changing the bitrate. Got the same with pearl harbor, atlantis and some other ones. Use AC3fix
[-Neoh*-]|[-Cheers-]
Panasonic DMR-EH50 and Pan. DVD-RAM disks inconsistent
By rehoboth in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Mar 2012, 21:50 -
Inconsistent Levels result with filter
By cornfluke in forum EditingReplies: 5Last Post: 17th Dec 2010, 07:24 -
Is anyone else noticing inconsistent conversion with DVDFab Platinum 6?
By MISS CHIEVOUS in forum DVD RippingReplies: 1Last Post: 25th Oct 2009, 14:16 -
Problem with MKV to DV - Inconsistent Quality?
By aboutblue in forum MacReplies: 2Last Post: 19th Apr 2009, 13:54 -
inconsistent audio sample rate error in FCE...
By ednarophati in forum MacReplies: 1Last Post: 23rd Aug 2007, 13:59
