  1. what are good or standard settings to put so you can put chapters where or at least very close to where you want them?
    like you should how many # of i pictures in a gop ?
    # of P pictures in a gop?
    # of B pictures in a gop?
    output interval ?
    max # of gop?
    i have set output to closed
    or should i use force picture etc...
    > i usally start with a svcd mpg or a avi to svcd
    not even sure what a gop is ? hehe
    thanks for any furthier help
    i will add i am useing TSCV to add chapters and menus with a intro clip to my first menu and then that one leads to either start film or pic chapter.
    the chapters are not quite close enought for me when i use the chapter buttons and that is ultimatily what i am trying to fix?
    then creating bin/cue with TSCV and then burn with TSCV
    if you need anyother info please post it and i will get it posted
    thanks again
    Mar 2002
    United States of America
    Yeah, set it to "Output bitstream for edit (Closed GOP)" as this setting is mainly for chapters. Don't use Force Picture. :P
  3. thanks i rencode the files that way
    is there a way to put the chapter anyother way ? like to force it to have the header ( i think thats what it need) no?
