which would you pick, quality-wise?
Results 1 to 10 of 10
I have the Leadtek 2000XP so can comment on that one. Qualitywise, I have found it to be excellent. It gives you every choice of codec you have on your computer to capture in and lets you customize everything from resolution to color correction. I do not have the Avermedia so I cannot really compare the two, but give the Leadtek my recommendations as it has excellent capture quality and TV/FM tuner quality, and lets you manually adjust everything.
I've have the AveryMedia Studio and love it. I recently purchased it for a very decent price. I run XP and have had no major problems. This is my first capture card, and it does everything it promises.
I did research all the TV capture cards, mainly using the "Top Rated" Caputre Cards option at this site. It proved very helpful. I made my decision based on price and functions. AveryMedia's Studio was the best priced for what you get, and it is "rated" pretty high.
PS: I've never used the Leadtek 2000XP so, my opinion is one sided.-Lineber -
Do you know if the Leadtek can playback and record TV in stereo? I read some user comments on this site about it but it seems to be a bit tricky.Originally Posted by Don2050
Yes it can....It plays back in stereo no problem, I had to adjust the souncard to playback "what I hear" to get stereo. It is a setting with the SB Live card I had. It took me awhile of fidgeting around with my soundcard settings but eventually I got it to caputure in stereo.
But in short, yes the Leadtek does output stereo audio signals. -
So, what does "playback what you hear" mean?Originally Posted by Don2050
I'm also curious as to how the cable connections work. When I used an ATI AIW Pro back in Win98 days, the capture cables for audio simply passed through to the audio-in on the sound card. Does the LeadTek use a passthrough cable too? Thanks.
(That was a surprisingly fast reply!) -
Yes the Leadtek works the same way....it comes with a 1/8" mini patch cable that passes the signal to the audio in on your sound card.
the 'what you hear' is just a setting on my SB Live sound card that I had to have selected to finally get my caputures to record in stereo....it was wierd cause selecting the audio in on my sound card only captured in mono...just a quark of my sound card really, not the Leadtek. -
all right thanks, maybe I'll get the card soon.
... or I might wait for the "Expert" version that is coming soon (though I'm not sure what's special about it yet) -
I just got the LeadTek today.
I have a problem with the recording -- the recorded audio volume level is very low compared to the original playback. Changing the 'recording volume' setting doesn't seem to help. Anyone else has this problem, or is it just my old soundcard? -
Do you know if this card will be a lifesaver to my problems:
https://www.videohelp.com/forum/viewtopic.php?t=144370
Regards,Jose Febus
Avermedia avertv hd-dvr problem
By ABUELLO in forum DVB / IPTVReplies: 9Last Post: 28th Feb 2012, 23:21 -
AverMedia Avertv HD DVR. Problem.
By streetkilln in forum Capturing and VCRReplies: 3Last Post: 9th Feb 2012, 20:37 -
AVerMedia AVerTV Capture HD with GraphStudio problem
By feeltherock in forum Video Streaming DownloadingReplies: 0Last Post: 18th Feb 2010, 13:47 -
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 10:46 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 14:22
