Well, as you decided to drag this topic up, here is a post also concerning this: https://www.videohelp.com/forum/viewtopic.php?p=638967#638967Originally Posted by RabidDog
As you said, the MHz is all that matters, but for general tasks a Celeron can not touch a P4.
The person concerned in this was wanting a seperate PC for vid encoding, which is the best option as it is cheap to buy a celeron, mobo and case etc.
Results 31 to 32 of 32
Sorry RabidDog, didn't read your full post.
Yes, a cheap AMD Athlon is definitely better than a Celeron, plus it can do so much more.
I personally would not use AMDs at all, it is P4 for me.
Just a note, remember the Celeron would be better for basically nothing more than encoding. It isn't really any use for doing real-time mpeg2 capture or anything else really intensive.
Upgrade Celeron 2.6 socket 478 & mobo
By kenmo in forum ComputerReplies: 2Last Post: 6th Jul 2010, 22:29 -
AMD Sempron Vs Celeron-M?
By Super Warrior in forum ComputerReplies: 8Last Post: 14th Sep 2007, 23:08
slightly old topic but! in tests done at tomshardware.com they simply advocate
