Im a little clueless on how to burn the files that DVD2ONE created from the dual layered disc that i used. I just got my SONY DRU-500A and am a little new to this. I use recordnow max and instead of guessing and possibly making a coaster id ask. All the helpful responses are appreciated.
Results 1 to 13 of 13
To start with go to file in Record Now Max
New Job
Data Disc
Then
Add Files Or Folders (THIS OPTION IS JUST UNDER VOLUME LABEL)
Add the whole VIDEO_TS folder
CHOOSE RECORDER/ SPEED / ETC
THEN THE BURN BUTTON -
You forgot one thing....must also add the EMPTY audio as:
AUDIO_TS
The the VIDEO_TS folder...
Bud -
Not big fingers....small keyboard...
You forgot one thing....must also add the EMPTY audio folder as:
AUDIO_TS
Then the VIDEO_TS folder...
***REVISED****
Bud -
I have followed the steps above in Recordnow Max 4.5, but get a error everytime I hit the record button.
Anyone have any ideas ?
I am using the trial version at the moment.
I have burned the files sucessfully using Nero 5.9.5.14
dlb. -
I used the new Nero version, which work fine for me. But i use Record Now at the moment. It's a great and easy to use programm.
One question. I never put a emptyaudio folder on the dvd and i have great sound. Why is it necessary to put a empty audio folder on the dvd? -
I just copied all the files to the Video_TS file in Nero 5.5.9.17 after selecting DVD-video in the compilation window. I burnt to DVD+RW, plays fine on my 4 DVD players (Hiteker(APEX) 1000,5131, Singer SDC001 and Magnavox MDVD100).
with nero they already have black VIDEO_TS and AUDIO_TS folders on it. so if you put yur VIDEO_TS folder on, it automatically adds an AUDIO_TS folder, i think
Justin
:agree: -
I use Record Now at the moment. This programm doesn't add a AUDIO_TS to the dvd. When i play the DVD everything looks o.k. So i don't think the AUDIO_TS is very important, but i coeld be wrong
?? you don't need an empty AUDIO_TS file ????
come on Bud , have u had too many ???
To be compliant with DVD the AUDIO_TS should be added, its on ALL store stamped DVD's.
I use the upgrade Recordnow DX and have no problems the DX version came with the SONY 500UL should have been included with the SONY 500a also. -
I'm a little bit confused now.
Should there be a AUDIO_TS folder on the backup DVD or not?
I have a few backups without the empty folder and they work excellent and i have a few with the empty folder: i can't find a difference -
Hi,
Ive been creating Dvds for about 4 months now.. this is my fast post guys ..
.this is how ive been creating DVDs..
Ive tried DVDx, nero,Record max,tmpeg ,cce,premire ..etc.
DVD 5s no probs-iso in DVD decrypter.
DVD 9
DVD Decrypter -file mode
DVD2 ONe- re encode
AVi MPeg -join vobs
DVD wise/tmpeg -de mux, to mv2 .audio
DVd Maestro - Author ,create image
DVD decrypter -burn
so far .ive had good copies of the discs ive written,and seems to take about 3-4 hrs start to finish.
if anybodys tried or is trying this combi ,let us know.any comments appreciated
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 03:48 -
I can't burn some files what can i do?
By rko2164 in forum Authoring (DVD)Replies: 1Last Post: 10th Jul 2010, 20:38 -
how can i burn these 2 files to a dvd?
By uglijimus in forum Authoring (DVD)Replies: 4Last Post: 24th Nov 2008, 16:15 -
Can't burn TS_Video files
By OzarkBaby in forum Newbie / General discussionsReplies: 5Last Post: 5th Jan 2008, 20:23 -
How do I burn .rar files and other
By cinemanetwork20 in forum Newbie / General discussionsReplies: 1Last Post: 28th May 2007, 10:48
