Question...When I am converting my audio in Besweet there is a section called "AC3 Encoding Options" which allows you to set the bitrate and has a box you can check that says "Create 5.1 AC3". How do I know what bitrate to select and if I should check the 'create 5.1 ac3' box?
-Steve-
Results 1 to 1 of 1
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 16:14 -
BeSweet for 4.0/quad AC3?
By RogerTango in forum Video ConversionReplies: 1Last Post: 17th Nov 2011, 03:16 -
Problem with BeSweet/BeLight. Trying to batch convert Ogg Vorbis to ac3.
By rayden54 in forum AudioReplies: 9Last Post: 30th Dec 2008, 18:37 -
audio conversion problems? (wav to ac3
By just in forum Newbie / General discussionsReplies: 9Last Post: 28th Oct 2008, 18:35 -
AC3 audio conversion
By exekutive in forum ffmpegX general discussionReplies: 9Last Post: 11th Nov 2007, 14:12
